Rear End Noise...
USA
Website
www.rutherfoto.com
OK. I have a noise I can't get to the bottom of.
When I come to stop, with in neutral or in gear, I hear a metallic "clinking and clunking'. It's a higher pitch noise, like something you'd expect from shot splines in you're d-shaft or something. I rarely hear it when accelerating form a stop. In addition, I put the 40 in 2-low, and idled in a tight circle, with my foot on the brake (chugging the engine) and I could reproduce the noise...
I recently changed all fluids: diff's, tranny, t-case...no signs of metal shavings, aside from the small metal sediment that collects on the magnetized drain plug.
I also dropped the d-shaft, and checked the splines (they were perfect) and all my U-joints (perfect as well) I also make sure the pinion bolts were tight. I also put the rear end up on stands, and looked for any abnormal play in the drive-line, or any unusual popping, clicking, grinding ect...everything seems to be working smoothly.
Does anyone have any other ideas? Should I drop the diff cover and inspect?
Thanks!
I am going with the little clips in the ebrake drum?
I have had a few of those come loose through the years and sound like that.
Did you check your pinion to see if it was loose?
Just guessing of course.
Got a limited slip in the rear diff? I have had one that sounded like that because somebody forgot to put the friction modifier in there.
no limited slip, but I do have an arb air locker...
