Was planning on taking apart the tcase yesterday to fix some leaky seals/gaskets. Got the car up on a friends lift & took the bolts off the rear drive shaft. But there was so much tension between the shaft and the companion flange that I couldn't get it off.
We tried prying it off with a bar, but it would just spring back into place.
Also tried lifting the rear diff a bit with a jack, but no luck.
As we put the car back on the ground, I only saw about 1/2 inch of travel in the shaft (got longer).
The front shaft I was able to remove without any problems.
From reading other posts, this is clearly not normal, and the culprit is that it's clogged with grease.
But what is the best way to unclog it and where is the hold located?
And what are the implications of driving the car when the rear shaft has that much tension between the tcase and rear diff?
BTW, it's all stock. No lifts or changes to the springs that I can tell. I'm not original owner.
Thanks!
Thanks!
