I have an issue that I'm not sure how to fix. The shaft retainer pin has sheared off inside the housing there is still about 1/4 inch of threads left on the bolt from what I can tell. I imagine the only way to get it out is drilling and using an easyout. The problem is getting enough access to the hole to drill. Is there a way to get the third member gears out without removing the pin. There does'nt seem to be enough play to get the C clips out.
Its on a 74 40 by the way. Thanks, Jeff
