rear body mounts
Think I would save those for a rainy day Jon.......a rainy day in Oklahoma!
I have a few more! Won’t part with all of them but happy to help someone if and when the need arises.
Anyone out there have some tricks for making the sun visors more stiff so that they stay up?
Isn't there a Phillips head screw on the visor at the hinge end that you can tighten to do that?
Don't know if this is an fj80 thing or not but the rear hub just sheared off the 6 botls that hold the axle in. I had the same thing happen a while back to the other side. Not fond of things just shearing off for no apparent reason.
Got another used hub. I have heard different things from people. I am going to use the same bearings from my broken one. Can I just use the races that are in the new hub? Or do I need to keep the races and bearings matched up?
Thanks for the insights.
You need to keep bearings and races matched!
We have new wheel hubs with and without bearings, and all the stud options @ Cruiser Outfitters. For example:
However, do you actually have an FJ80 or is it an FZJ80. Sounds like you definitely have a full-float so either swapped or non-US
