When I do the rear disc conversion, I'm going to actually pull out the axle shafts so I can remove the backing plates without destroying them. I figure while I'm at it (don't they all start this way?
) I'll replace the oil seals and the bearings as well. Looking in my FSM, it looks like you have to pack the bearing, install it, then the oil seal goes in outboard of the bearing. Is this right? I would think that the gear oil would wash the grease away from the bearing in short order, or is that okay to happen with these bearings?
