Real Time..Size of the nut on the ERG tube to Cooler
The ERG tube comes off the back of the manifold and through a large ass nut as it goes into the cooler. I need to know the size of that nut. And the dia of the cooler tube?
I can't tighten it up unless the cooler and pipe are bolted up and there is not much room to work. So I was thinking of buying a crows foot or like the brake line tool with the opened end.
Any one have this tool? P/N?
Thanks
Shane
Dan helped me with mine. We hooked the j pipe and cooler together just tight enough to twist the j pipe . then bolted everything together loosely. once all the bolts when in then we tightned everything down. it doesnt leak but I was wondering how tight it really should be. I was thinking of dropping the exhaust out of the way and manifold below the heat riser to tighten it up if it started leaking.
All my EGR stuff is sitting on my shop floor :) ,
The big-ass cooler nut is 36mm, and the OD of the cooler tube is 25.5mm.
