Thanks in advance.
I just replaced two broken wheel studs on the passenger rear. Followed the the FSM, the FAQ and all the YouTube videos I watched. That went fine until I went to re-install the rear caliper. Everything I looked at made seem to be a slide off and back on affair
The pads were tight on the rotor and there was a big gap between the caliper and the mounting surface. Ok, tried compressing the piston and it reduced the gap. They gap narrowed but still contacting the rotor a bit. No mention in the FSM of doing anything but compressing and making sure the pads were seated.
I figured it should figure itself out when I torqued the wheel down and give it a since it looks like a sliding caliper.
It seemed to free up but I’m getting some rubbing when I drive.
What did I f up now?
Seems a little better after some hard stops but not gone
