After posting the other day with several problems that i've been having the consensus from all you guys was, fix the gas leak first then go from there. So here we go
I set out to find the leak and it is coming from the top of the gas tank where all the hoses and wires connect. Pardon my lack of terminology but I'll describe the best I can. Is there a gasket under the circular thing on top of the tank that could be replaced? Can you replace that entire circular metal piece? If so, does it just screw off all together? The tank itself on the bottom and around the sides all looks good, it's not rotted through or anything. Just around that top circular thing is some rust and you can see the gas coming out from under it when the truck is turned on. I attempted to disconnect the hoses and one of them even broke right off, the one with the screw fitting as you'll see in the pictures. The other just had a hose clamp on it and that pulled right off. Only other thing connected to it is the yellow plug with the wires through it. Can't figure how that plug comes apart or if it even does.
I included some pictures so you can see what I'm dealing with, hopefully it's not too bad of news and I can get a new circular piece and salvage the tank itself.
Side question.... the bed is very rusty and rotted so I wouldn't mind even getting rid of it all together and laying down some wood for a flat bed. Anyway, how much goes into just yanking the whole bed right off. Sure would make gettin at the tank easier too.
Wow long post, so sorry but I'm learning on the fly here guys. I'm excited to be working on vehicles finally.... I'll be a master mechanic before yanno it lol. Seems I keep wanting to take one thing after another off
Thanks a lot if you even took time to read this.
Matt
Matt
ability lol.
