Real time cv axle help needed ASAP please!
Southern, CA.
Rebooting my cv axle passenger side, tried setting the diff side first then pulled the cv axle out to reposition and saw something like a metal rubber band hanging, what is this??? Did I screw something up, can it be reset?
That is part of the seal. It goes inside the lip and is a pain to put back in. Don't bother putting the axle back in till you fix it or replace the seal.
Looks like you need a new seal.
Thanks for your quick response! Is it easier to remove the seal at the diff opening to reset this ring? If not I presume the seal will still need to be removed for the new one so worth a try?
I removed the seal and was able to re-assemble the spring on the inner side!
Back on track, I ordered a seal just for back up, rebooting about every 50k Anyway. Going with clamp style vs. OEM bands supplied with boot kit this time. Thank you guys, appreciate your help, have a nice weekend!
You may regret not replacing the seals. Not a big dollar item.
Just curious. How'd you even get the seal out without tearing it to shreads?
I went ahead and replaced both after all,
I carefully pried it out with large screwdriver. Came out pretty easy.
