(Re)Setting sunroof limits after replacement?
New Orleans/Houston
Hey Mud,
During LCDC I took a rock to the sunroof and the glass shattered. After replacement of the glass I noticed the I had to hold the switch for any operation, and when closing the sunroof I have to manually stop it in the correct spot or it will continue up like I am pressing the "tilt" function. Does anyone know of a limit reset or something that can be done to stop it in the correct position or make it go back to auto travel mode?
Thanks,
-Josh
Here you go buddy. I wanted to answer you earlier but i was busy.
Ive had this info on hand for a while meaning to get to this.
This is one of the many factory defects i need to address on my own vehicle. Mine does not fully seat when un-tilted back to close. Only when fully slide closed.
There is an additional wind hiss i get if i dont close it the "right" way and its annoying as hell. I both notice and care about these things so im hoping this will fix it for me.
This is what I was looking for, thank you so much. I will give it a try tonight.
Update: worked perfectly. Thanks again!
