The problem is the rebuilt engine as the harmonic balancer already on, there is a exposed gear you can see where the IP bolts into has a set of 2 teeth with blue paint on them, there is a set of 3 times with blue paint thou.
I would assume that you would set the harmonic balancer at 11 deg BTDC?, see the attached photo shows.
The problem is which one of the 3 sets of blue lines marked on the gear to use, you can in the attached photo the twin blue lines which are exposed at 11 deg (and down lower another set just exposed).
The third photo shows a plug on top of the casing where the IP bolts onto, this is a inspection point to check the gear position.
The last photo is of the IP gear, I have checked everywhere on this gear and the only thing I can find is "2", does one highlight this tooth so it shows thru the inspection plug or does this tooth go between the teeth of the gear with the 2 blue lines?
How does one re-install a IP without pulling the harmonic balance off and the front gear cover off?
PS. Is it 4 revolution of the crankshaft for firing? so as each set of blue line pass by, the last set of blue lines at BTDC 11deg that are exposed is where the IP is "positioned, by painting the tooth that has the "2" on it, that is what needs to be seen thru the inspection plug?..............anyone for comment?
