I am in the process of compiling my build list.
I current have an 03 LC, bone stock. I will get bigger tires (in addition to many other things), but larger tires begs the question, should I re-gear?
I have gone to larger tires in the past on other vehicles, and noticed a significant change in power off the start. I am also considering that I want to record actual mileage, correct speedometer, and accurate Navigation. However, I recall in the stock Navi menu there is a choice to make changes for a tire change.
Are there concern related to the transfer case?
Am I right to assume with the front suspension, there is only 1 ring and pinion set, which is in the rear?
This is my first 4wd with IFS, so go easy on that question!
I have crawled around underneath and only see one!
Finally, how difficult, on a 1 to 5 scale is the project to re-gear the LC?
Ultimately, I would be fine with a re-gear if it meant I could maintain power and speed as experienced at stock.
Thanks for all the advice!
I have crawled around underneath and only see one!Finally, how difficult, on a 1 to 5 scale is the project to re-gear the LC?
