RCI skid plates
California
Anyone install the RCI front engine skid plate with a differential diff drop? Wondering if it'll still be a direct bolt on or not. Thanks!
If you have stock front bumper you can order an rci filler plate as well because the plastic OEM one wont be able to attach to the new skid. Its a good setup.
The RCI I have on my 5th Gen 4runner works with a diff drop kit in place. RCI's site should say if it does or not on their site when you go to order yours.
Finally installed my RCI bumper filler and engine skid plate. There's 1 inch clearance between the bottom of the swaybar and top of the skid plate. Wondering if this is enough space clearance. I know the passenger side is rigid so it won't move. Driver side could probably use some trimming. Thoughts?
This is Victory4x4 steel front KDSS skid
Thanks for the pix! Do you have diff drop installed? Stock bumper?
I decided to trim the driver side the width of the swaybar just for piece of mind. However I noticed that the diff support is sitting/touching the skid plate. I might have to go a different route if this presents a problem.
I don't run diff drop. My skid drop down about 1" below the diff. There is a pocket to clear the diff.
Below is picture of non KDSS skid. I did not take pictures when I installed mine.
