Here’s a great little product I wish we all would have known about sooner. Ratiotek kits RT-AB60E and RT-AB60E-PRD (heavy duty version) are available for roughly $50 - $60 if one shops around. The RT-AB60E kit recently found a home in my Tundras valve body, and the results, while subtle, are a refreshing upgrade that I suspect many around here will appreciate. The whole process of moving up and down through the gears is sharpened up, shift speed is increased noticeably with very slightly firmer engagement, I wouldn’t even use that word to describe it, but these things are subjective… nothing even close to harsh or annoying. The laziness is reduced substantially. I have no experience with the HD PRD suffix kit, but suspect it will be less daily driver friendly.
The kit contains a handful of springs and two drill bits for enlarging valve body main plate holes. While I’m tempted to call it one of the best bang for the buck mods out there, many will scoff at $50+ for what easily fits in the palm of your hand. Also consider that the installation requires removable and disassembly of the valve body, requiring multiple hours of work, and keeping track of a high number of small parts… it might be considered a tedious job, even for the experienced. Those that need to pay a shop for install can expect, my best guess, 3 - 6 hours of labor depending on installer experience. Anyway, it’s still pretty high up on the satisfaction list of mods I’ve done. While I’m not going over the install in this thread, there is an excellent thread at Tacoma World showing the install of a similar, but not identical kit, into an A750F Transmission. FYI, the AB60 transmission is heavily based on the A750, so it gives a great general idea of the work required. Also note that various other valve body wear parts may require attention while in there, Sonnax and TransGo are great in their offerings here.
www.tacomaworld.com
RatioTek transmission upgrade how to
Here is a good do it yourself upgrade to your 5 spd automatic transmission on your Tacoma. The kit is by Ratiotek and cost about $30. It increases...
