Raindrops keep falling on my head......
So after rain started to get a little bit of moisture falling on my head when I turned or stopped.
Nothing crazy couple of drops.
Reached up above in the side of the track where the sun shade slides and there is moisture.
Where should I start looking.
Plugged drain tube for your sunroof. open roof and check the front corners where the drain ducts are.
Open up the sunroof. Then cut a 7' long piece of weed-eater line and snake it down each of the holes you'll find in the corners of the sunroof to clear them of debris. Check by pouring a small amount of water from a water bottle down each one and you should see the water hit the ground under your LC. That may take care of your problem. Good luck!
I have a similar problem, happens to be a few drops on the passenger side. Wife is not happy! Lets say it rains hard for a day. The truck is dry while sitting but I start driving and that must slosh whats sitting in there a bit and it starts to drip off the side rail side. I reach up and there is moisture there. I cleaned the front drains with some weed wacker line and tested, water drains right out. I cant seem to find the rear drain holes up top. I found the exit underneath the truck and fed the line up but it gets hung up at a spot pretty far along and I don't want to press to hard to dislodge the drain line. I couldn't see where the rear drains are from up top. Any advice for finding them or did I just not try hard enough?
