- Thread starter
- #41
Trany Cooler Pointers
The hose from the trany to bottom left inlet of radiator (original oil cooler) does not change. I busted the end on mine when taking it off so I took it to my local semi truck mechanic who makes custom hoses all the time and he crimped on a tube fitting for me and saved me from buying a new hose.
The exit hose from your radiator oil cooler goes to the inlet of the trany cooler. This is where I used a brass barbed elbow from McMaster Carr. It screws into the radiator oil cooler exit and you can then hose clamp the provided trany cooler hose on to the barbed end.
Inlet to trany cooler and exit to trany cooler use basic male fittings that rubber hose goes over and hose clamps on.
I routed all the hoses through the same area that the condenser hoses go through (to the inside of the passenger headlight.)
Once you know all your hoses are going to work right you use the provided zip tie things to attach it through your condenser. Use the provided spacers to make sure your trany cooler is not flat on your condenser. It will not help cooling for your ac or your trany if you forget to space them apart.
Here is the final install pic and the orientation I chose (notice that my grill is off as it makes attaching the cooler extremely easy.
