radiator mount pic needed....
Dana Point/San Diego CA
Hi All,
Specifically looking for pics of the 2 radiator side mounts. I believe these have vibration isolation grommets in them.
Just confirming those mounts as mine seem to be floating (no assumed grommets).
Thanks:beer:
I couldn't get a picture loaded on this device but if you're talking about a horizontal surface mount to a bracket at base of radiator on both sides, yes there seems to be a disc similar to an engine mount. it's about 1-1/2" diameter and about 1/4 to 3/8" thick. it's either rubber or a high density black plastic. a metal washer on top of it.
Hi VtaTom,
Not sure if we are talking the same.
I'm looking for a shot of the 2 upper mounts (L & R). The are on the either side of the radiator about 3/4 of the way up from the bottom.
Let me know what you see....
Not sure a 2000 LX would be the same, but on mine there are grommets that are in two pieces connected together that fit into the mounting bracket - part number is 16584-66010.
At least some LCs use the same part - it's #2 in this illustration from this site.
Yup, those are them.
Guess PO (or, more than likely service provider) omitted reinstalling:doh:
Just another item I have to address. I better get on it as I suppose that radiator is moving w/o 'em.
Makes me wonder what else was omitted....
Anyway, thank you for verifying.
