Radiator Hose (1 Viewer)
Stephenville Tx
I guess I have been living right due to I stopped my the auto parts store to pick up a switch and when I walked out I had coolant leaking onto the ground. I found I had a split flex hose from my thermostat housing to the radiator. So with much searching in the store I have found the perfect fit for a 350 with a 4 core radiator.
Gates 22437 for upper radiator hose.
I have been looking for a replacement for a while and thought I would share with someone searching in the future what worked for me. Now I need to get a new lower one and that one has some odd twists.
Gates sells it as two parts. Engine to pipe and then pipe to radiator. The engine side is 2" and the radiator is 1.5" I may have the part numbers written down, as I try to keep that and belt numbers listed in the shop. You will have to "cut to fit" the Engine to pipe hose. It's almost cut in half. I'm sure Toyota makes a one piece option if it's still available. It may even be cheaper than two hoses and a section of pipe.
HTH
Brittain
Wait, I just read it again and I now think you're going from a 350 to whatever your radiator is not a 2F to the stock radiator. Is that correct?
B
Fjeng they have the gates hose numbers in faq section if your looking for the bottom hose number. Thats for a sbc converison. Sounds like you are living right
Ill look in the FAQ for a bottom hose, yes the hose I used was for a SBC conversion and I did a quick search and didn't see that number listed so I just wanted to throw it out for someone to be able to search later. Hope everyone is having a great weekend! Oh and it is a stock 4 core radiator
