Radiator hose part identify help!
California
Hey guys, can you tell me what this hose is called? Seem to be long overdue for a replacement. Thanks!
I would not order from Toyota parts deal they suck, but they have a Decent site for looking up part numbers
As stated, thats a 16267-66020. If you're replacing that one, you should also replace the throttle body bypass hoses, 16264-66021 and 16261-66040. The Throttle body hoses aren't much fun to do- it's easiest with the throttle body removed. And while you're under the intake pulling the rear throttle body hose of the nipple it fits onto, have a look at you PHH and start planning that one too.
Be sure to replace all the small hoses at the same time, Friend didn't change the one that is hidden on the other side of the throttle body and it cost him his engine.
Wow.. I am very new to this. What are the hoses that I should replace?
Thank you! What’s PHH?
The fat little hose next to your starter that goes to your heater valve, rots from the inside and blows when you can least afford it.
