Radiator for FJ 40 V8 Conversion
California
I am currently shopping around for the best radiator and water pump setup for my V8 converted FJ 40. My wife and I are moving to Northwest Arkansas at the end of the month and I do not want to worry about my truck overheating. Currently running a salvage radiator slapped on by the previous owner of the truck.
Any suggestions?
Is anyone using the Man-O-Fre Radiator that says it was designed for V8's?
Max
Hi Max, I can give you some input from hee in Australia as I have just installed a 350 and overheating was a big issue. I bought a custom radiator setup with aluminium radiator and twin electric fans from Jeepcity in Queensland. Supposedly specially designed for V8. Well, first run and it was so close to boiling I took it straight back to the shop. From all the research on Mud I thought it needed a good shroud. So I sourced a big flow electric fan. The mechanic said he would re-use the original shroud and when I went to pick it up he had switched back to the original FJ40 fan and viscous coupling. Well, this improved everything dramatically. It still ran warmer than the 2F but I think Chevs do anyway.
But I was concerned that it was still quite warm under the hood and on the firewall, so I spoke to a business that ceramic coats and decided that I'd do the headers (block huggers). That did the trick. Almost back to normal temp and under the hood is fine, all the heat going out the exhaust.
The added benefit was an almost chrome like ceramic coating that doesnt discolour and less noise from electric fans. I understand a couple of HP are lost on the belt driven fan but the chev has plenty to spare. Also had the shroud powder coated to match the aluminium radiator - quite a bit of bling now!
Graham
I'm running a stock radiator and sbc water pump and electric fan on my 350. The only time it has over heated so far is when I forget to turn on the fan (manual switch). Mines just a trail truck though.
I second the 3 row aluminum radiator (Champion) from ebay. I put one on my SBC400 converted 40 and my overheating issues ceased. I'm running a mechanical fan and no shroud, although at some point, I will install a shroud. For summer, where it has been 100 degrees many days this year in NC, I run without a thermostat, but may put a 160 in and leave it for the year.
My OEM rusted through on my 69 w/ 350. After hunting around, I realized an awesome custom radiator builder had his shop near my house, and I had him put together a quad-core copper radiator with dimpled tubing. Great radiator, and it was really fun working with someone local. Ran me about $500 though, but I'm confident it will be the last radiator I ever buy.
Best,
Guy
I'm running a 4 row radiator w/ Ford Taurus electric fan. I installed a 2spd D C Controller from Delta Controls. It works great. Welcome to Arkansas.
