kcjaz
I assume the 0.9 stamped on the cap is the pressure rating in bar so 13 psi correct? I’m using a pressure tester beforeI I fire her up after water pump replacement.
That does not appear to be OEM.I assume the 0.9 stamped on the cap is the pressure rating in bar so 13 psi correct? I’m using a pressure tester beforeI I fire her up after water pump replacement.
