Quick wheel stud question
Sheridan, Wyoming
Hi All,
I am doing a disc brake swap on a fj40 using 84 fj60 knuckles etc. I have bought new rotors and thought I would replace all the wheel studs at this time since several were broken on the donor parts. The question I have is the new studs I bought from napa are loose in the rotors. Is this the way it should be? Should they be tight going through the rotors as well as the hub? Thanks
Brian
the studs should fit tight....sounds like you ended up with early 40 studs.... the studs you need fit 8/'80-8/'87....
Hi all,
Just to clarify the studs are loose in the rotors but tight in the hub, is this correct or should they be tight in both? Thanks.
Brian
Update:
I went to the trash bin and checked the old studs and rotors, and the studs are loose in the holes of the rotors but tight in the hub, so I am going to assume that this is the way it should be. Thanks all.
Brian
