Thanks! I see.It’s for cruisers without AHC (and for those who removed their AHC, although at that point the lift would probably be referring to the starting height you would have had if you had traditional suspension to begin with).
…Unless you’re specifically talking about an AHC lift, which generally just means modifying the height sensors to make your ride heights all a bit higher. You can go deeper into it by adding a shock brackets, but that’s about the extent of an AHC lift. I think it tops out around 2.5” extra. Usually measured N to N but probably the same L to L and H to H.
2-2.5" AHC Lift Using King Coils & Shock Spacers
Well all my parts finally showed up and this past weekend I lifted my LX. My goal was to have a 2-2.5" lift (using the AHC system), while keeping close to stock travel characteristics and stock neutral pressures. Components Installed: KING KTRS-79 Coils (sourced from eBay seller sparesbox_auto)...forum.ih8mud.com
Is the ride-height for an AHC equipped 100 in N the same as the ride-height for a non-AHC 100?
When people are referring to a 1-2" inch lift or whatever kind of lift really, what is this compared to? AHC in N mode? or is it AHC in High?
Thanks
Unrelated photo for your troubles:
Mostly, for our convenience we all use measurements from hub centre to fender lip to express ride height. The hub to fender measurements are independent of wheel/tyre size but are not independent of 'lift'. These are approximations and are not part of the actual specifications given by Toyota in its Factory Service Manual (FSM).
Love the 100 fender flairs, what brand are they, and do they require cutting the original fender sheet metal?
Depending on who you ask. One of the Dobinsons vendors told me their lift numbers are over tired and sagged suspensionWhen people are referring to a 1-2" inch lift or whatever kind of lift really, what is this compared to? AHC in N mode? or is it AHC in High?
Thanks
Depending on who you ask. One of the Dobinsons vendors told me their lift numbers are over tired and sagged suspension![]()
Wow. So in theory someone could get a 2 inch lift kit, but end up at a lower height than with the AHC in "H"!
