1. Does it matter whether or not the air injection ports are open when taking cylinder compression tests?
2. What is the optimum rpm driven by the starter for a good compression test?
3. Will a bad valve adjustment affect a compression test?
I'm testing a 2F motor from a 1977 FJ40LV-KCJA, it's been sitting for about 20 years. Drained the oil, no water present, replaced with 5w30. 1st test had bad ground, corrected and also replaced tired starter.
Valve train function looks good. Put some MMO in the cylinders 5 days ago. So the following results could be a wet test? #1 60 psi, #2 115 psi, #3 80 psi, #4 100 psi, #5 90 psi, and #6 90 psi. I haven't taken a huge amount of compression tests but a fair number and usually the numbers are closer to each other even with a bad engine, do these numbers indicate something I'm not seeing?? Thanks for any help!
