question on replacing coil pack or packs
I wouldn't go with an off-brand like that set.
Just go with the one that the code is showing. May want to buy a spare for the glove box with your mileage.
Haven't done it on the cruiser but replaced one on the LS... same procedure.
I would stay away from off-brand coils. I recommend Denso. You can get them locally at NAPA. If you're a AAA member, you'll also get a 10% discount. Of course, you can also order online from Amazon or your favorite on-line retailer.
I've got one AutoZone Duralast coil in mine as well. (I was desperate) It's been in for over a year and hasn't failed yet... It is listed as having a limited lifetime warranty. About the same price as the Denso coils.
I followed the masters instructions and did what I was told. @lt1fire you think I should change the plugs? If so what should I get denso?
What Onur said.... no reason not to at the price you can get them for.
Well just get locally.
Call me when you need to discuss a problem like installing an H151F behind your 2UZ and you need to know what computer to use and have your immobilized work.
that would make the cruiser so much nicer.... I don't think i'd have room to use the clutch though.... #tallpeopleproblems
@fourtrax trying to get a bunch of maintenance and preventative stuff done. Need to figure out why my rear locker is not working.
I really want a 5 speed manual. I need to compile the list of parts. These trannies are starting to show up with the bits in Aussie junk yards. Could be in UK junk yards as well.
H151F
Pedal box
Stuff
More Stuff
Etc
H151F
Pedal box
Stuff
More Stuff
Etc
I'm sure the master above can help ya out.....
