Yes I have read over the link about 20/22r hybrid in the FAQ
I am looking at a 1984 xtra cab and the seller has installed a 20r head on the block. He has some sort of adapter installed in order to run the 22r carb with the 20r intake. He hasn't started it since the build and none of the vacuum lines for the carb are installed. It turns over and has 103+ compression on each cylinder. He says all it needs to run is the vacuum ports on the carb and intake plugged and the distributor cannot be adjusted due to the power steering pump brackitry in the way so this needs to be solved.
I have a few questions
Will the fact that the distrubotor cannot be fully adjusted effect the timing enough that the truck wont run?
Can i really just plug the vacuum ports on the carb and intake and it will still run, ignoring the emissions factor?(I live in SD and dont have to worry about emissions)
Any questions regarding the 20r/22r hybrid design i should ask him?
Your help is much appreciated.
