Qikazz fan and hub kit (1 Viewer)
This is for Diesel 1HZ engine not 1FZ-FE
Biggest running warm or overheating issues in Australia are 1HZs with after market Turbos. This is the market this fan is for, suiting 1HZ powered 'crusiers like 80 series, 70 series and 105 series. .
A large percentage (Maybe majority) of 80 series in Australia came with the 1HZ ( or other 1H block diesels ) rather than the 1FZ-FE. (As an aside I have driven an after market Turbo 1FZ-FE and that was a lot of fun :) )
There is also this similar available but it is available with different sized spaces to locate the fan in the optimal position in the fan shroud Engines Australia high flow fan :
Also this PDF covers the testing done:
If you compare photos of this kit and the Qikazz kit, they are the same thing. Maybe Quikazz sold rights to E.A?
They do not appear to be exactly the same. I own the Qikazz model and the adapter appears to be different than the EA model. Functionally, they are probably the same.
Following up as I have the fan now installed. Noticeable difference in temps. About 8-10 degrees F cooler on average, which is about what they claim. The fan is definitely noisier, but I can't really tell over the sound of my diesel engine. If you're looking for the most cooling possible, this is a no-brainer. Works as advertised.
