Wanted Pto winch parts
UK
Looking for 3 parts to complete my pto winch install.
The final joint into the winch.
The chassis bracket
The control lever and mounts
I have the winch, pto shaft and take off...
Can anyone help?
Thanks.....
Bump.... I am still looking...
I've got a bracket from a 55 series, it was a prototype made by Awlteq. not sure if it is similar enough, it looks like the one you want is for a 40 series??
Hi... yes I am after one for a 40, the bracket I should be able to fab/make..it’s the other two items I will struggle to make or replace with modern substitutes...
What year are you dealing with? What transmission and transfer case? From mid 63 to 1/79 everything same the same except for the change from three speed to four speed. Then shift rod and driveshaft got longer. 1/79 on these made changes every couple of years.
Hi,
It’s a H55F with split case trans... was hoping for a transfer shifter from the 80’s to better match the later year of the car... its an 81/82.
The winch is of unknown age but was used over a range of years....
