PTO Removal/ transmission Q
Vidor, TX DIXIE
Once I remove All the pto equipment, what do y’all use as a block off plate. Not talking about floor of the cruise but the actual transmission once lever and whatever the part is called that a yoke is attached to?
You can make a plate from a thickish sheet of aluminium or steel...And seal on with silicone ..... If you get a gasket you can use that as a template. You could even make it out of a sheet of timber until you get a proper one.... Only has to hold in fluid....
