Propane Kit for 2f
In Between Worlds
I might be interested in some of the stuff. I already have the 425 and everything, but I would like the components that make it dual fuel. electronic cutoff, fittings to the carb etc. Also, I need some tank brackets.
Let me know what all you have.
Would like to sell whole, but if someone else wants the other components, we can work something out.
Ok, can you send me some pics of everything...may be willing to get all of it.
Isn't the 425 too big for a 2F? I thought everyone is running 225 kits. I am about to do this conversion, but not dual fuel, so might be interested pending your reply.
:beer: R
I have the 425 and it works pretty well.
attachment.php
Sorry...it works really well.
It has been some time since I switched back to Gas, but when I had it on you could enrich it and get really good power if you wanted and then lean it out for economy.
The only downside is that it needs a choke mechanism or something to enrich it for startup as the system is running lean during cold starts. There is a little cold start device on the evaporator which helps, but it's not great. I personally would like to find an adapter to put the 425 in series with the aisin carb, then I could start on gasoline, switch to propane after warmup.
I am still considering, if you can reply to my email answering those questions - thanks!
