Builds Project Overland
Oh, I also finally got around to installing a passenger grab handle...
Hand Throttle
About two years ago I broke the clip on the stock hand throttle when I was removing it. I have since done without it, but I have missed its functionality for idling up for cold starts and off road. For awhile I have tossed around the idea of moving the hand throttle to the shifter which would be a little more ergonomic and free up another hole in the dash, something I never seem to have enough of.
I am aware there are kits available for this, but since the pedal assembly is already set up for one, I figured it would make for an easy home-brew project. Here's what I ended up with...
Parts used:
  1. (x1) Rear (more indexes than the front) Bicycle gear shifter and control cable
  2. (x1) Bicycle control cable casing- About 33" long, you can buy it by the foot from any bike shop
  3. (x1) Casing end cap - these just slide over the end the casing for better finish, also found at a bike shop
  4. (x2) M5 nuts
  5. (x1) crimp-on end stop (I used a non-insulated electrical butt connector)
  6. (x1) plastic sheet metal clip - The square kind that you pop into a hole to accept a screw. I got one at my local body shop for free, it's just a matter of finding one that fits into the pedal.
  7. (x1) Spacer bushing - for mounting the bike shifter to the cruiser's shifter lever.
  8. Zipties
Assembly:
I started with the cable casing and popped the end cap on one end. On the other end I threaded on the two M5 nuts. This was a little tricky because it was a tight fit, which is good since I wanted them to bite into plastic casing. I used a razor blade to taper the casing just a little at the very end so the nuts would thread on straight, and the slowly threaded on the nuts one at a time with a pair of pliers. I "cut" thread with the nuts about 3/4" up the casing. These nuts are used to secure the casing by sandwiching the bracket in front of the pedal and for adjusting the final tension of the cable.
I already had a bike shifter and it's actually a pretty nice "rapid-fire" unit made by Sram with a ratcheting mechanism which is good because it locks up in "gear" to resist the pedal force. It already had a control cable in good shape, but these can be bought new at a bike shop as well. I slide the casing on the the cable with the end cap on the shifter side. Then I slid the casing into the bracket in front of the pedal, allowing the nuts to sandwich the bracket. With the shifter in the floor board, I made sure the casing was fully seated against the shifter and then measured how long the cable needed to be to go through the pedal with enough room to crimp on the end stop. I pulled the cable back out, cut the cable, slid on the plastic clip and crimped on the end stop. I put it back back in once again to see how close I came, and made any adjustments by moving the nuts up and down the casing until I was satisfied. Here's what the pedal end of the assembly looks like:
Mounting:
Standard handle bars are 7/8" in diameter, the diameter of the cruiser's shifter lever, is not, at least not where I wanted to mount the hand throttle. To make the spacer bushing, I used a small chuck of 7/8" Diameter aluminum round stock about 3/4"-7/8" in length that I got from my local metal supplier.
The shifter lever is tapered so I need two diameters. I measured the shifter lever about where I wanted the top of the throttle to mount, and about where the bottom would be. It was a about 9/16" at the top and not quite 5/8" on the bottom, so i started with a 1/2" drill bit, drilling all the way through, and worked my way up in size until it slid down the lever to where I wanted the top to be. Then I drilled about half way through the bushing with increasing size bits for the bottom diameter until it seated nicely about where I wanted it to be. Then I just tapped it in place with a hammer for a "press fit," slid on the hand throttle assembly and cinched it down. I routed the cable down the lever, under the heater ducts and up to the bracket securing it with zipties along the way. Then I secured the casing, slid the cable into the pedal slot, and popped in the clip. Done!
I am VERY happy with the way it turned out. So far it works perfectly. I can ratchet the rpms up to about 2200rpm using my index finger, and ratchet back down with my thumb...
Up...
Down...
would have it been easier to just replace the OE hand throttle? Yes, but doing it this way gave me a little more functionality, and a whole lot more satisfaction. :)
I like it! I've seen it done with a rotating style gear selector, but I think I like this better.
Spring Plans
As you know, I haven't made a lot of progress over the last several months, but that has given me time to work out a few bugs since the rebuild ("phase 1") last summer. Now that I have everything pretty much where it should be, it's time to enter phase 2 of the build: Outfitting!
Here are the plans for the coming months:
  1. Turbo - I did it. After a couple years of saving I finally threw down for a turbo kit for the 1HZ. :cool: I went with a kit from All-American Imports out of the Netherlands. What I liked about this kit is that it uses a lot of Toyota parts including a CT26 turbo, HDT exhaust manifold, and boost compensator for the fuel pump all for a pretty fair price. It came to a little over US$2400 at today's exchange rates including shipping to the US. No intercooler, at least for now, and I plan to keep boost at a modest level to maximize fuel economy and reliability. We'll see how long that lasts. :D
  2. BEBs - As part of the turbo install I plan to replace the BEBs as a precautionary measure.
  3. Oil bypass - Also related to the turbo install, I plan to fit an Amsoil oil bypass filter to help keep the oil extra clean for the engine and turbo.
  4. Dual Batteries - I just got my new SS battery trays for my dual battery set-up. Haven't decided on batteries or module yet.
  5. Cargo System - I gave away my old set of plywood drawers. They have served me well over the last few years, but it's time to change gears a little. This is still in design phase, but I am looking to integrate more storage, a fridge, etc.
  6. Armor/Gear - This is a long list of gear that I will probably be picking at over the next year or so as funds permit. It includes: recovery bumpers, winch, sliders, roof-rack, rooftop tent, long rage fuel tank, on-board water, on-board propane... You know, "the basics."
  7. Misc - As I type, I have a set of 16" wheels and a split rear bench on a boat from Australia (thanks jsaltlick!). The wheels will eventually get a some 255/85 MTs serving as my expo wheels, and the split bench with be installed to allow for the new, more modular cargo system.
Quick Sidebar: I have to give props to Maarten at AAI who has been putting up with me for the last two years. Seriously, I have been emailing him since March 2006 about this kit. He has been amazingly helpful (and patient) with answering my questions, finding the most inexpensive shipping method and piecing together a "custom" kit for my somewhat unconventional application. For a while, I was even considering to buy everything but the CT26 and getting a Garrett domestically instead to try and save a buck. Maarten was happy to accommodate, but with the euro down I just decided to pony up for the whole shebang. He had earned the business, and I probably would have spent the same money and a lot more time in the end regardless.
PICS:
  1. AAI Turbo kit
  2. Boost Compensator
shiny parts! nice!
keep it up.
whenever you want to make the sliders, plan a trip back to cashville and we'll do 'em right.
malphrus
yeah, i'm hopin to finally make a set of those rear quarter sliders in about 3 weeks.
found a guy here in nashville that is goin to let me borrow his 62 for a day or two to fab em up and test fit them, etc. i'll shoot you some pics when i get em done.
malphrus
Almost forgot...I added dual batteries to the list on post 287. I just got my new SS battery trays!
Where did you get the SS trays? I thought the guy who used to make them quit a year or so back.
