Project Lockjaw - aka Stretch Arm Strong
bluehawk
Appalachia Cruisers
Knoxville,TN
The build has started.
1973 Fj40
Dana 60 front axle
Sterling full float rear axle
5.3L Vortex engine
4L80e transmission
Atlas t-case
4 link rear
3 link front
Got the transmission up on the stand and started cleaning on it.
Went with the 4L60. Its shorter and has a lower first gear in it.
Got my Barnes4wd axle truss today
At least there are two guys who still get on here from time to time. I think its gonna start coming together pretty quick.
Lol, yeah, the mid TN clubhouse is pretty dead as well. I been following the main thread. Looking good so far.
Speaking of, how did the frame chop go?
Haven't started it just yet. Going to get on it this coming week.
Got the 4L60E back from Dustless Blasting.
Before pictures and last one with some high temperature primer on it.
Got some good used Toyo tires from my buddy Mark Redden in Virginia.
Started the frame stretch process today. Gonna be a lot of work but well worth it in the end.
The plasma cutter makes short work of the brackets. Love using it.
Took a break on the frame. Decided to take a peak in the engine. This was a junkyard motor I got from a friend and oh my goodness. Please change your oil on a regular basis.
Good thing is: rockers, valves, cam, pistons, and mains look really good. The only thing that needs changed is the timing chain. Time to clean it all up.
Worked on the frame today. She is 12" longer now
Had a little visitor show up in the garage to see what was going on. Released back to the outdoors
Nope, I'm out on the snakes. Otherwise, excellent work
Engine is going back together. New intake gaskets and valve cover gaskets so far. Waiting on timing chain gear set and oil pan gasket.
