The transmission vents out the shift lever tower I believe, as there is not a separate vent fitting...
Thanks Mike!
As I said, I am concerned with air starvation/efficiency... I'm hoping someone who has used both air ram and precleaner will provide some insight...
If you use the Ram Air where does the air filter go?
Everything I've seen/read places the filter under the hood... I suppose you could place it in the middle of the stack, but what I've read says that placing it under the hood supplies cool air.
@SouthBostonFJ40 - Alex: it is very hot under the hood, do you feel your metal filter acts as a heat exchange, heating the air before it gets to the carb?
I don't plan to use the 'river' box... I don't plan to drive that deep in water... But, if you do... Your should probably use something like the box to waterproof the filter.
Alex's bullet-type filter is a 5" polished aluminum can, with 4" inlet/outlet I don't see the airflow all that restricted. I have already desmogged, so I have room for it. I will install a heat shield with it, if I go that way. HERE
Where is the '78 t-case vent located? 44's still out Doing Vegas...
Thanks,
Seal distributor with silicone or. ?
you should be able to go to the top of the fenders without a snorkel,once your in that deep the fuel cap can leak water in and the dipstick .pcv fittings that are not tight will leak and let water in .a problem with the dissy is they are warm when cold water hits them they condensate inside and kill your vehicle .make sure its vented well ..plug wires need to be in great condition .i usually seal mine with battery terminal sealer the clear stuff from napa .i usual put a plastic bag over the dissy to keep any stray water from hitting it directly .dont forget the clutch housing it will fill with water and rust the clutch and everything in there eventually .good luck
The filter in the metal housing is actually very free flowing and I'm not concerned about about heating up this air. My engine runs so much better with this set up.
As far as removing OEM parts, I have a 2F with F manifolds and power steering. A 2F air cleaner will not fit because he carb is at a different level. An F air cleaner won't fit because the power steering pump is in the way. My choices were limited so I went with a snorkel.
You don't want to do that; ozone can build up and explode. The stock dizzy evacuation system on your '78 works well to prevent this - make sure it is operational and all hoses in good shape. The vent for it is fairly high in the firewall and the other hoses for it go above the dizzy to a VCV just below the air cleaner.
On stock 3FE-equipped Cruisers there is a neoprene (?) cover for the dizzy that snaps all 'round it pretty tight; you might look for one of those (though the 3FE dizzy has a larger cap than your '78 2F).
O-zone... That's an interesting theory that I've never heard before. Ozone only lasts for only a few seconds, and is limited to the a mount of air inside the distributor to begin with. If it were a concern, why are they 90 percent sealed to begin with?
Dangerous thoughts Danny!
I can see you progressing along these lines very soon (top to bottom):
https://forum.ih8mud.com/threads/distributor-cap-exploded.372078/
https://forum.ih8mud.com/threads/distributor-venting-exploding-caps.300486/
https://forum.ih8mud.com/threads/fj62-signal-generator-bad-do-i-really-have-to-buy-new-dizzy.186529/
This one has a good diagram of the stock dizzy evacuation system:
https://forum.ih8mud.com/threads/distributor-cap-vent-vcv-issue.639725/#post-9730784
https://forum.ih8mud.com/threads/distributor-cap-vent-holes.571645/#post-7440780
