Power Steering Pump & Hoses Replacement
Thanks Timmy! Have you noticed LC's need more repairs/maintenance than our beloved 3rd gen 4runner? Mine is at 225K miles and still OEM Steering system!
P/S pump fails (leak) due to low quality fluid. Use a branded fluid such as mobile-1 and you should be good. experienced that in our Hilux.
At 14:20 you can see the lower radiator hose is not well mounted.
I don't think a 100 Series is any better or worse maintenance wise. I do think the 2UZ-FE engine is superior to the 5VZ-FE in longevity. The achilles heal of the 5VZ is the heads. They are knows to crack. I told my buddy about the radiator hose. Thanks for the heads up.
