- Thread starter
- #21
Allright, i'll just have to dig back in. I may as well open both sides while i'm there. I'm heading to the beach this weekend so it may be a week. I'll post back what i find.
IdahoDoug said:You're going to have to pull that birf - I'm 98% that it's damaged badly. Fortunately you've got a spare if you get in there and it's more than the birf's inner clip having failed. Actually, that's wishful thinking - I'm not aware of anyone breaking that clip in use. But maybe. Hmmm.
Anyhow, get that thing out before it grenades and takes out the ABS sensor, which we all know is big $$$ since it is only available from Toyota with the entire harness. Could damage other stuff as well. Congrats on noting it before it went kabloooie!
I'll be interested in hearing what failed in there.
DougM
Bear80 said:I'm really curious to what it could be, but I think you should check your front pinion nut. Though usally if the pinion nut is lose you'll get what sounds like driveline/u-joint noise.
Bear80 said:Is the possibility of the rear end fully rulled out??
