Any easy way to tell if this dizzy was curved for a 40 versus the advance curve for a GM motor? It is my understanding that GM distributors have way to much advance for the 2f.
I don't have Jim C or Mark A's knowledge but this happened to me....
Long before there many commercially made Landcruiser HEI units available I installed one that I picked up from a small cruiser shop. It was pretty simply done and I believe it still had the GM gear on it. I knew better but it was going to be temporary as I had been putting a bug in Davis' ear about these and was pretty certain I had convinced them to manufacture a "good" one. ( My apologies to Mudrak and Up n' Over who were apparently doing excellent versions already. I just didn't know it.) The shop's instructions were "Drop it in, set timing to 10ºBTDC, and go".
About five minutes into the first test drive the engine stuck a piston (or something) and shut down. That's the only way I can describe it. I was doing about 40mph. After pulling over and regaining composure I restarted it. The engine fired right up and I drove off. About five minutes later it did it again. I was ten miles from home on a empty road and no phone so, after a brief pause, I restarted it and limped home. I only drove the vehicle for a few miles at any one time for the next couple of years as I was working on it at two different locations depending what tools I needed. The symptoms never recurred. I never heard any pinging and the engine always seemed to run a little hot but better when really warmed up.
When I put a better unit in (not a DUI) I tested the advance curve on the old distributor and was a bit surprised. It had something like 17º of vacuum advance, maybe 24º mechanical at around 2500rpm (iirc), plus the 10º initial. I'm pretty sure it had never been rebuilt and had probably been pulled off an old Nova or something.
The engine eventually needed rebuiding much earlier than I anticipated and I'm pretty convinced that the few, short miles I put on it with the over-advanced GM spec distributor really helped wear it out prematurely. The machinist said the cylinders/pistons/rings were especially bad. This whole time I had the same Jim C. carb I still run and yes, vacuum advance comes in at 6" and ends at 12".
Tale over.
