POR-15 Tank Repair - Long Term Report
Stuck between a rock and a hard place
Well, simply put, I am not pleased.
Six years ago I installed my subtank and non-US maintank assemblies. Both had some rust flashing on the inside, so I thought using POR-15 Tank Repair would be a good idea. I followed their extensive instructions to a T, with all of the cleaning and drying stages. The process takes several days to get the prep and coating done. The inside of the tank looked great after cleaning, and I should have left it at that.
Now after pulling the sender unit to replace with a Diesel one (for my conversion), I noticed a 3" piece of POR in the tank. Then after closer inspection it was apparent that the coating was bubbling in many places, and was fairly easy to pull off. The only places where it was having issues was on the upper half of the tank, thus I suspect that the fuel vapors and increased methanol in the tank are the culprit. Luckily there appear to be zero small bits and pieces, just large strips. I had the sender out three years ago, and there were no telltale signs of any issues at that point.
I am sure there are those who would say that poor preparation is to blame. Trust me, it is not. Newer fuel blends have destroyed what should have been a lifetime coating. Now I need to pull both tanks and have them hot-tanked to get the gunk out. It may end up cheaper to just get new tanks shipped from Japan, though.
Simply letting others know, use POR-15 Tank Repair at your own risk.
full
Good to know. And if you think the sender unit is undamaged send me a PM I would like to purchase it.
Thanks for the heads up and timely post. I'm about to swap tanks and you confirmed my concern about trying to treat the one I have here currently with oxidation inside.
Had a pin leak in a Jerry Can and used Por-15 to seal them up.
Thanks for the look-out.
Are you sure you followed the preparation directions? ;)
I used their kit when i put the 4.3 in my truck had to modify the Toyota tank to fit the Chevy fuel pump,m mine was dry for month before and i did not put gas back in it for 2 months, have not had a problem. its been since 2010 .Maybe i was lucky.......... maybe it was the extended drying time,or maybe the new fuel mixtures they sale now ate it off your tank.I would contact them and see what they have to say about it.Or maybe cause I'm in the smog nazi state they wont let them put anything into the fuel that would make the car run better.
The level sender unit is staying with my rig. I will at some point be selling the cover/pump assembly which has the proper fill/transfer hose for the gasser motor with a subtank, including the EFI pump.
Yes, 110% about the cleaning, dry times, tips, you name it. My suspicion is that some of the new California fuel blends exceed the 10% Ethanol limit, and other additives which are being used to reduce smog are eating away anything which is not steel. It was clear that there were blisters forming between the metal and the POR-15, as one of these additives has the ability to penetrate the POR-15. These bubbles were still pressurized, and metal was clean below, thus not due to a pin-prick in the coating, nor contamination or corrosion below. I bet that the coating would be fine with older fuels, and just simply cannot deal with the new formulations. YMMV, as this is just my personal experience and observations.
Ebay!
RED KOTE GAS FUEL TANK SEALER LINER REDKOTE QT.
FREE SHIPPING - NO GIMMICKS - FREE SHIPPING
3 ratings
Seller information
mckchchc (6696 )
99.9% Positive feedback
Follow this seller
See other items
Item Information
Item condition:
New
Time left:
Time left: 7d 21h 1/14, 11:49AM
Quantity:
4 available / 13 sold in 24 hours
Price:
US $24.99
Buy It Now
Shipping:
FREE Economy Shipping | See details
Item location:
Saint Petersburg, Florida, United States
For Metal Tanks Not for use on Plastic or Fiberglass Tanks
Red-Kote is an internal METAL fuel tank liner designed to seal leaks and prevent further rusting. Internal rusting is caused by condensation in the fuel tank or by bad fuel. Red-Kote will seal in existing rust to prevent it from flaking off and plugging the fuel line or carburetor. As a sealant, Red-Kote excels at sealing the often hundreds of pin hole leaks that occur along seams or where straps wrap around the tank. After you solder or patch the major holes, Red-Kote will seal all the leaks too tiny to find. Once in place, Red-Kote forms a very tough, flexible membrane that will never crack or flake as many competitive products do. Red-Kote will not plug lines or cause engine damage when used properly. Future rust will be prevented because condensation will not contact the metal. A serious problem with one or two of the liners on the market is that they are dissolved or loosened by gasoline additives. One coating seriously damages the carburetor if alcohol- contained fuel is used. Red-Kote has been tested with all of the fuel additives that Damon is aware of.. One Quart Per 12 Gallons of Tank Capacity. Red-Kote can take approximately 48 hours to dry.
SHIPPING TO ANYWHERE IN THE CONTIGUOUS UNITED STATES INCLUDED IN PRICE!!!!
RADTANK
Since 1951
2643 22nd Avenue North
St. Petersburg, FL 33713
1- 800- RAD-TANK
(1-800-723-8265)
I have used KBS fuel tank resto kit. So far so good. Being that these tanks I have used it on are in 1960's trucks it only makes since to find and use non-ethanol. Old carbs, old style fuel filter and NOS sending unit it is worth finding the non-ethanol. My town of 10,000 we have two stations with it. Different though, resto trucks and not DDer's.
Cheers
Pulled both tanks today along with the sensors and main filler.
Subtank is 100% fine with no bubbles or peeling in the POR-15 coating. I have decided to leave it alone.
With the Maintank, it appears that only the coating from the seam upwards and some of the baffles have peeling. I am wondering if the top of the tank has a different factory material or coating, such as galvanizing. I can reach into the tank and peel off sections from the top no problem. The bottom is rock solid with zero bubbles or peeling. Scratching my head on this one for sure.
Have a gallon of Methyl Chloride to strip the coating, but still contemplating. Can source a new tank for under $400, so may go that route.
