- Thread starter
- #21
Pic #10 shows the flapper stuck in the middle, the base of the intake had a ton of buildup on it and the gasket where the two meet was in bad shape.
Where did you take it to get sandblasted?
how much did that run?
Took the parts to Advanced Power Coating on Deming Way in Sparks, 3 pieces blasted cost $37.
So I got the Manifold and air intake back from the sandblaster and started priming and painting. The heat riser will have to be manually operated from now on as the spring and counter weight did not survive, but you can see the flapper is still intact and functioning.
Maybe you could find a good spring and couterweight off a Chevy six manifold. Toyota copied much of the older Chevy engine.
Don't forget some locktite on the pitman arm nut. I know it's a horizontal shaft, but I've seen 3 of them come loose this summer.
Hope to have this back together by the weekend and then it's on to the clutch. Received all the clutch parts just in no frame of mind to tear out the drive train any time soon.
