Short story: Failed.
Long story:
Read some blogs, watched lots (!) of YouTube vids, knew the challenges - really it's all about the ridiculously fast dry time.
1. Washed and dried hood
2. Used 1/4" vinyl pin stripe to create the blackout - much more flexible than standard masking tape
3. Then, used 1" masking tape to overlap the pinstripe
4. Then, masked the rest of the hood, fenders, windshield.
5. Okay, the tough part - lay down enough Plasti Dip to get a good thick, even layer... in under 5 minutes. The tape has GOT to be peeled before the Dip dries. I got 3/4 of a can down in even, fast applications, tossed the can and started peeling.
80% of the tape came up leaving razor sharp edges... the remaining 20% were drying, sticking to tape... peeling... I had to use a razor blade and gently (but quickly) cut as I went.
6. All peeled... looked like crap
Clearly more "paint" had to be put down. This was evident when I peeled it off. In all the videos, it comes off in one huge sheet, with little to no effort. I spent over an hour removing that section - no piece bigger than a quarter. The reason - too thin. Well WTF. Clearly - because it was drying - I didn't have time to finish the can and start another. All of the edges would've peeled.
The punch line - the rattle can approach is NOT an option for the blackout panel, well... maybe if you have 4 guys - 2 spraying working their way to the center, while 2 more peel... uh huh.
Oh well - $6 down the drain
Long story:
