Pinion angle
Anyone know how many degrees for the front and rear the pinion would have to be rotated. 76 FJ40 2f, 4speed, SOA, 35s? No lift and a 2.5" lift calculations? Thanks
http://www.4xshaft.com
WAY too many variables to be sure....it will depend in part your drivetrain install and the angle the t-case sits. Not sure I've ever witnessed two the same.
Plus, running a CV rear shaft means the rear pinion points AT the t-case, running no rear CV means you want the angles the same.
