Ive noticed some cruiser (specifically the gray ones) with the pin stripe removed. What the best way to get that off?
whatever you do don't let some bozo buff it out ..it will burn the clear coat and fade the paint prematurely...
Are you referring to desert pin striping (s****es from trees) or the gold stripe as seen on many UAE vehicles?
If they are just minor scratches, just use some StratchX and elbow grease.
Its the sticker style put on by toyota. After doing some research I think the best way is to heat up slightly and peal away.
