Pics of the Icon Rear Control Arms for the LC200.
Southern California
They weigh about 20 pounds and feel VERY beefy.
I love the teflon coated pad they have on the under part of arm to protect the arm damage. It is also replaceable, so if I get it torn up, then it could easily be replaced.
They are extendable via a large hex nut on the end. They also have zerks for adding grease later.
They should hold up VERY well.
They are getting installed on Monday.
Below are the pics.
Notice the zerk in the upper left:
Nice little 'ICON' Label:
Notice the large Hex between the end of the arm and the joint. That is what gets turned to get the correct length, then you used the two hex screws above the end to tighten it and set it.
The underside of the adjustable end. Notice the screw threads in the space:
The replaceable teflon coated plastic padding:
Should be a nice addition.
I will post pics when I get her back.
those look sweet. cant wait for my 200 to be welcomed into my family so i can then drool and justify the purchase of these new parts.
I know these are the same ones they use on the FJ's.
Arms look fantastic. What does ICON say about the strength AT THE THREADS? At first look I see that cracking or breaking if the beefy arm gets hit hard. ???? Whatcha know?
Questions emailed....I will post the answer when received.
