Parting Out Petersburg VA: Parting Out 1999 Mercedes OM606 I6 3.0L Turbo Diesel
Petersburg
Hey all, I’m parting out an OM606 out of a 1999 W210 E300D. Unfortunately the engine overheated and melted the front two prechambers, so the head and block are damaged and every piston was damaged from sitting. Many parts will work on a variety of OM60x engines such as the OM601, OM602, OM603, OM604 and OM605. Some have already sold but here is all the rest of the parts I still have along with prices (all parts are in good working order unless otherwise noted):
6x Turbo Pistons
All have some damage, some are worse than others. Might make a good desk ornament or as dummies for fabrication purposes.
$15 each
6x Turbo rods
All are in good shape and perfectly usable. Includes wrist pin and circlips
$50 each
Block & crankshaft
Crank is in perfect condition. Block has some scoring/gouging on the walls but nothing too major and it should be fixable with sleeving or an overbore
$200 but let me know if you want to buy just the crank and not the block or vice-versa
Head & valves
Cylinders 1 & 2 would need the prechambers replaced at least. They would still be damaged but would probably work fine in a non-performance build.
$100
Cam retainer housing w/ cam caps, both camshafts, & drive sprocket
$300
Harmonic balancer/front pulley
This is the updated one-piece part that is better than the earlier versions
$80
Dipstick tube
$20
Timing chain & all 3 guides
$20
Power steering pump bracket
$20
Fuel heater & prefilter screen assembly
$20
Bosch EDC Pump electronic control section
This is just the rear electronic section of the pump. The front mechanical section has been sold in order to have its 6mm elements harvested
$40
Water pump pulley
$20
AC compressor mount bracket
$50
Alternator mount bracket
$40
Injection lines full set
$60
Valve cover w/ oil cap
Does not include the plastic vanity cover
$50
Timing cover
$80
Flex plate & spacer
$20
EGR crossover w/ clamps
$50
Oil pump w/ drive sprocket, chain, slipper & tensioner assembly
$50
Turbo oil drain block fitting
$10
Crankshaft pulse position sensor
$20
Fuel filter head w/ mount, lines & lift pump
$100
I’m located in 23805 and can meet locally or ship on buyer’s dime. If you buy multiple parts I’ll cut you a deal and you get to save on shipping.
Discussion Starter · #1 · a moment ago
6x Turbo Pistons
$15 each
6x Turbo rods
$50 each
Block & crankshaft
Head & valves
$100
$300
$80
Dipstick tube
$20
$20
$20
$20
$40
Water pump pulley
$20
$50
$40
$60
$50
Timing cover
$80
Flex plate & spacer
$20
$50
$50
$10
$20
$100
a64d8a0d-97cf-48de-9dd3-aeea117b3bd3-jpeg.132704
88adffc2-4190-4c4d-9f20-f55440be953b-jpeg.132698
47570ad9-f455-4669-9dc6-54c8bdc9c5be-jpeg.132699
216dd32b-ad3f-4177-a03a-6fbc434d47ea-jpeg.132700
5f5445a4-a41d-4aa0-a9ae-93624dfce3ae-jpeg.132701
25e5eb9b-280c-4043-b0e5-b8326e827194-jpeg.132702
c8da8af4-0b43-44d3-a217-5d72b6a64ec2-jpeg.132703
