Per Requests: Simple Self-Made Exhaust Skid Plate
Hi folks following from the "exhaust options" thread, here are some simple suggestions on how to make extremely simple and extremely strong exhaust pipe protection.
Steel Stock:
All flat steel stock is 4" wide 1/4" thick steel. You will want one piece 4"x2" (this is the angled up section of skid), one piece 4"x3" (this is the front-most frame rail connector), one piece 4"x8" (this is the rear-most frame rail connector) , one piece 4"x12" (this is the main horizontal section of skid).
All rectangular tube stock is 1"x2"x 1/8" thick steel. You will want one piece 6.5" long with a 60 degree cut at top and 60 degree cut at bottom such that the cuts are parallel to one another this is the front-most section (see photos), one piece 4.75" long with a 45 degree cut at top and 45 degree cut at bottom such that the cuts are parallel as well this is the rear-most section (see photos).
Two custom bolts 3/8"thick with center square section of 3" and length of 7.5" to go over the frame rails and attach the skid plate.
Since I made this modification I have put the thing to the test several times...it easily supports entire weight of the side of the vehicle when lifted with floor jack and I have smacked the snot out of it over and over while wheeling.
Some simple hints:
1. To get the 60 degree cuts, I firmly and forcibly clamped a 45 degree framer's tool (see photos on saw) to the table of my chop saw (not the table saw) and then set the miter of the chop saw to another 15 degrees. The rectangular tube stock lays against the framer's tool so you get 45 degrees there and then the 15 degrees from the miter of the chop saw. Please note everything must be firmly and forcibly clamped down to avoid movement. Please also note that all the abrasive blades out there flex some especially at these angles so go super slow particularly as you start the cut; once the blade burrows a straight starting slice it will follow that through pretty precisely.
2. As you should see from some fotos, I super carefully scribed center lines on all stock. This helps the accuracy and alignment of the pieces as they are welded along. Also as you should see, I super carefully scribed lines where the bolt holes go which were 3/4" inch back from the edge of each piece that is through bolted. All of this helps the accuracy and alignment. Also I used the table to align everything, then tack welded, then measured and measured again, and then finish welded. In the end the plate was so accurate i was not able to measure any mistakes in alignment at all.
Hope this helps you fine fellas protect that poorly placed pipe under the frame. As I have written here in other older threads I too wanted to take the pipe over the frame but for reasons ranging from safety to simplicity, I went with the exhaust that goes under the frame. With this protection I have the best of both worlds as far as I see it. Again HTH... :cheers: :cheers: :cheers:
Pics of stock...
Some assembly shots...
Some finishing shots ... both on and off vehicle ...
to avoid something like this?
Make one for me
Pleeeeeeeeze? :D
Doug, that is RUDE!
Nice design and build on the skidplate. LOTS of folks should be downloading this info...
As usual very impressive Turbo. :cheers:
Sure glad I don't need one myself cause I taint got the skills. :doh:
Thanks Turbo!
NorCalDoug said:
Make one for me
Pleeeeeeeeze? :D
Thanks Doug, although I absolutely would love working on one for you, I can not and should not; "can not" because of the time thing, and "should not" because depending on the make and model of your sliders, exhaust, etc., there may be minor adjustments made prior to permanently welding the two top frame support sections to the primary skid plate section. My guess is that the plate works perfectly with 99% of the trucks that are out on or off road but if any adjustments at all are required it would be way better to make them prior to the welding work. Still thanks so much. :cheers:
Thanks Clown, I hope lots of folks do download this info, not just to protect the pipes but also to avoid the potential problem of serious heat soak into the interior of the rig. Now that the plate has protected me many times while wheeling without ever even coming close to hanging me up, I really feel relieved that I made the right choice in choosing to go under the frame. Sure somewhere in my mind I still prefer the idea of going over the frame but without the lovely body lift option like on your awesome rig, I just do not have nerve to do that. Anyways, thanks so much. :cheers:
Thanks Bro, ohh, let's get the good thing right...you have the skills you just dont have the need!!! Damn you for your authentic Safari over the frame exhaust!!! The one exhaust out there that truly does not need big body lift to work with over the frame!!! Fawker! :cheers:
Dusty said:
sweet fabing and a clean looking shop to boot
Thanks Dusty, I like things to be clean enough to eat off of, part of its my OCD and part of its my CSD - chronic spillage disorder! :D :cheers: :D
Wrench said:
Thanks Turbo!
No problem Wrench, anytime at all I can help here I am more than happy, no matter how hard I try to equal the help i've received from this forum, i'll always fall somewhat short; that's the terrific thing about this place, well, that and junky's momma!!! :D :cheers: :D
96LX450 said:
Turbo,
Nice work!
What is your welding setup comprised of?
Thanks man, the welder is a lincoln mig welder (sp-175) with slightly customized cart and a 75/25% shielding gas with lincoln autodarkening helmet. Most of my results are really from practicing on classic cars with sick sheetmetal - that teaches more than most other materials about penetration, perforation, voltage, and speed, etc. :cheers:
I don't have this problem on my superior `94! :flipoff2:
