- Location
- United States
I picked up a clean '87 that had been driven at speed into a transfer truck. The owner had just finished fixing it up ie the OME suspension, some new mechanicals, new paint etc. Most everything on the truck is good. The only things that i dont have are the front sheetmetal/trim, radiator/condensor, steering box, mirrors or taillights. I will itemize everything else and put a price on it. Good stuff first for the most part. If you want something i dont list that i havent already said i dont have, shoot me a pm.
I will update with pics as soon as possible, if you want a particular pic let me know. Payment will be through paypal or check/cash. Everything is pulled and ready to ship, i have access to a UPS shipping computer and everything will ship from a business address unless it is too large to ship without freighting it in which case ill work something out with the buyer.
These will be shipping from my work in 23220, Richmond, VA. Local pickup in Amelia, VA.
**I have dropped many of the prices as of 1/3/10, make me an offer on anything**
OME ultimate light/medium lift, low miles, pics will do its newness justice, includes everything in the kit incl. steering stabilizer
750 SOLD
H42 four speed shifter tight, no leaks 80
splitcase with linkage, vgc 200 make an offer
rear axleshafts long side 50, short side 40
rear axle housing 25 local pickup
front third member, 3.73 50
birfield/inner combo 50 long side, 40 short side
front axle housing 25 local pickup
2f long block, ran well before wreck, possibly bent shaft on water pump
300 local pickup only, will sell head with cover/valvetrain for 150, will possibly break down more if desired
intake manifold 30 SOLD
exhaust manifold 30 SOLD
toyota reman alternator 60
toyota reman starter 65
smog pump 30
all the smog junk on the fenderwell 15
coil, good shape 25 SOLD
aisin carb, good running cond. 100 SOLD
choke cable, switch works 25
good air cleaner assembly 20
carb insulator 10
carb fan 25
rebuilt PS pump 60 SOLD
A/C compressor 50
clutch assembly with flywheel 75
ebrake assembly with cable 40
clutch master w/linkage 30
brake booster, new bendix rebuild, with the pedal linkage 50
good boots for shifter/case 10 for both
complete wiring harness, including motor 40
good guage cluster 25
ashtray panel with all switches 10
pedal bucket for 4spd swap 40
rear doors, clean with no dents, fresh maaco paint so new but not perfect in toyota red, good tint on windows, with door panels, glass, and window cranks 70
back glass, no cracks, good tint 15 per
rear hatch, fresh paint, no rust, tint 75
rear tailgate, chrome little faded on trim but solid, 125
back seat, no rips, blue/grey, 2 peices 30
rear heater 25
relays from kick panels, wiper, cleaner (which i presume to be squirters), cooling fan, seatbelt warning,emissions, 10 per
cargo area panels, good condition 20 for all SOLD
rear seatbelts, with tensioners 25
cargo light 5
dome light 5
driveshafts, front and rear 50 a piece
low mileage fj62 front diff, 4.11 125
good skidplate, no rust through 30 bucks, local pickup its big
charcoal canister 20
solid frame, no rust, local pickup 100
spare tire crossmember/chain assm. 30 bucks, prefer local pickup
FJ62 smog pump, good cond. 30
tie rod and relay rod, ends tight, boots GC 50
drivers side 60 headlight surround, pic below 20
center console w/cupholder 25
60 wiper motor 25
750 SOLD
smog pump 30
carb insulator 10
carb fan 25
A/C compressor 50
rear heater 25
cargo light 5
dome light 5
60 wiper motor 25
