For Sale Parting out a couple of 2f engines
NorCal
Let me know what you need. OBO, +shipping, etc.
I will make a great deal if someone wants a bunch of parts.
rebuildable block - free to a good home
set of rods - $60 (pistons maybe not good, but free if you want them)
crank shaft - $100 (guaranteed good if you have 500+ posts)
head complete including pushrods - $100 (head bolts if you want them)
iskendarian cam - $100
bell housing - $75
inspection cover (early style, no dent - $20
flywheel - $75
intake manifold - $75
exhaust manifold - $75 - pending
'75 carb core - $75 - pending
carb insulator - $50
fuel pump (qty 2) - $25
side cover - $25 (add full set of original bolts +$10)
front cover - $25 (bolts +$10)
oil pan - $100
crank pulley (qty 2) - $100 (nut +$10)
2f valve cover - $35
oil cooler (bent tube) - $10
oil filter bracket - $20
water house and cover, no broken bolts - $40
'75 carb linkage rods setup (4 pcs) - $100
I'm looking for, for my '78, a dome light cover, a fuse panel cover and I'll post if I think of anything else.
Fast Eddy,
Do you have a thermostat housing with a BVSV valve? Year? Color?
Yes. It's a '75, probably CA. I was planning to keep the BVSV, but if you need it, make an offer and it's yours. I'll post the color later tonight or tomorrow. I was asking $40 for the water house and the top cover. It does not have a provision for the oil cooler. I might have that one around here though.
has the crank been turned? what year did the the rods/pistons come 9out of? Domed or flat
Flat pistons from a '75. I have two cranks. One has been in my garage for five years and was in the POs garage for years before that. I'm strongly guessing not turned. I'd have to buy a better caliper to measure it. If you get it and you can't use it for some reason, like a crack, I'll refund.
The BVSV looks like a brown one.
Rariator request
Got an fj60 2F stle radiator without leaks?
I may be in need of a crank pulley if I can get mine off. Do you still have one and will it work on an '85 FJ60 2F?
I may have one for you, if I can get it off. :) I'm going to be working on my spare spare this weekend. I believe it will work on an '85. I'd post in the tech forums to be sure before you buy mine or any other. I have an '85ish 2f, and the pully is different. It has a 3rd pulley that is not used in my application. The one I have is two pulleys.
