parting out 87 hj60
heater-lower section
Looking for the AC lines. From firewall to compressor and compressor to evaporator.. shipped to 08204 if you have them.
Thanks
Still have parts avail? I need the Toyota emblem/license plate light assembly from the rear tailgate if you've still got that?
Hi Mike,
I 'kissed' an elk yesterday.... Do you have the right front headlight surround and turnsignall assembly?
Thanks
Yes sir, my headlight survived, but the headlight door and turn assmbly were smashed... the bulbs survived! Lucky it wasn't worse.
Shipped to 83455, for Fifty$ ?
Thanks,
Mike
Things I need:
P/S pump and brackets with hoses
P/s Resivoir
12HT head pipe
late model cross member with brackets (to fix trans clocking issue)
Throttle cable assm
HJ used fuel tank
Air cleaner to engine ducting
New Aluminum Rad
Fan shourd
drs side battery tray
12V starter if the one I have isn't
Things I would like but could live without or make:
a/c bracket
engine wiring harness with glowplug timer
Tach for diesel
Also a front driveshaft .
Again I would rather buy a whole hj60.
Trying to save time since this engine and trans were not in a half cut. Would you do a half cut?
