Part Number? / Part Name?
Colorado
Does anyone know the part number for this wire harness cover / protector / shield that runs under the carpet and scuff plate on the driver's side? It covers / snaps onto the metal ridge, has short spikes on top that help hold the carpet in place, and covers the wire harness running along the floor just inside the door. It's a little over 2 feet long. Mine has a lot of splits and breaks. It may be an NLA part, as I can not seem to find anything on this part. Thank you.
I don't think you can buy just that part as it is part of the carpet as a whole.
Thanks, Scott. That would explain why I can't find any hint of this part in any of the parts diagrams or on-line parts stores. Its not attached to the carpet. I also wondered whether its part of the wire harness for the cab. The old plastic is getting brittle and is cracked and broken from being stepped on so much over the years. Too bad there's no replacement for it.
If anyone has found an alternative or replacement, please chime in. Thank you.
In some of the first pictures you posted you can see the staple holes in the carpet and the rust from said staples in the plastic.
As far as a replacement, you could check out Lowes/Home Depot or even McMaster Carr for some type of channeling.
Thank you. That is a great suggestion. I didn't realize those were once staples. They're nearly completely gone now. Much appreciated.
Hopefully you are able to find something that suits your needs.
