I'm doing a timing belt job + a number of other things. I am remediating a number of things the previous shop did 60k ago (or didn't do). All of the harness clips on the drivers side upper cam/timing chain cover are broken.
Here is my cover:
This is an ebay listing that shows the harness clips I need (unbroken version).
So far my research has brought me to Partsouq which shows these PN's. They only show two clips like the image from Ebay and I don't trust the accuracy of the part numbers for my application.
My clips that hold the harness are "ratchet style" clips that clamp over the top which is missing in their diagram. Then there is one open clip (90467-09031) I believe, which on my cover is very brittle; and then the slide style clip which is intact.
Anyone run into this where they had all of these clips broken?
I figure in this situation I'm just going to use zip ties with the push clips. I have multiple large assortments of clips; thinking I can just use these:
Unfortunately anytime I move this harness I'll have to remove the cover to replace them unless I can find the Toyota clips.
Here is my cover:
