Hello,
1985 4Runner parking brake not disengaging. It has been doing this for as long as I have owned it (one year). When you disengage the parking brake put it in reverse (does it going forwards too, but not as bad) it is very hard to get going. Earlier today I had to put it in low range on level ground in order to be able to back out of a parking spot.
When I pull the parking brake lever the cable on the rear axle gets tight, but when it is not pulled there is a lot of slack in the cable. I don't know much about drum brakes, but it seems like the lever that the cable attaches to on the backing plate should spring back to the disengaged position by itself. Here is a video to show what I am talking about:
Thanks
Thanks
